1 wire or 3 wire alternator, AQ260 V8
My Sierra 1 wire alternator just died last weekend. The new Sierra alternator (part # 18-5951) is a 3 wire unit. Where do I connect the two additional wires?
Any thoughts appreciated!
Chris
Re: 1 wire or 3 wire alternator, AQ260 V8
Chris
Ayuh,... Welcome Aboard,... Why not just replace it with the Right 1,..??
The single wire is not OEM, and neither is the one you are trying to install. You will have to add a wire to the system to use that alternator.
You may already have a purple wire near the alternator that was removed from the OEM alternator. That would hook up to the black wire on the alternator plug. You will need a 16ga wire from the engines circuit breaker (output side) to the red wire on the alternator plug.
