120 cracked block repair
gatorred
i have a 120 inboard cracked were frezze plug are is there any way to repair this with jbweld or weld it, in the open side of block,in strait line,crack.
cobra 3.0
Re: 120 cracked block repair
I've used JB Weld on my exhaust manifold and it worked great.
As long as there's No Water in the Oil Issues,......<br /><br />Epoxy of Many kinds have Saved those motors....
Gary H NC
grind it down a little then put some jb weld on it....could be a cheap fix
thunderroad
yeah..grind it down, then spray the area with brakekleen or a similar evaporating solvent/cleaner to degrease it and bring on the JBWeld. You've got nothin to lose.
DayCruiser
Ensign
I sent mine to cast iron specialist welder. No leaks all of last summer and it looks good this year--knock on wood lol Not inexpensive, but the dealer who screwed it up paid for it.
gatorred
it broke in side will no turn over all the way maybe some one put stuff in it,my trailer wire's were played with,they may have trashed motor to <br />traded other boat&motor for complete in board 120 that run's ok.
