120 merc. upgrade options?
clintbeastwood
Yep i think my blocked is cracked on the inside. Oil is a lil milky, but not to bad or high on stick havent hade time to change it. If it is cracked what options do i have i dont want another v8 like i had in my old boat it was hard on gas. Is the 4.3 ok on fuel will it bolt up , my out drive strong enough? where can i find a good reman 2.5 ? 1973 starcraft ss 2.5 with old outdrive
Re: 120 merc. upgrade options?
Ayuh,... Yer only Upgrade option is a 3.0l, 140hp motor...
It'll bolt up, without issues...
The 4.3l will require changing the outdrive to a different gear ratio...
clintbeastwood
ok well i guess its not gona be a hard choice if it is cracked
bondomerchant
those lil 140s are quite an improvment over the 120 with the high cost of fuel on the horizon that would be my choice
Fishermark
I agree the 3.0 liter is a big improvement. Before you go pulling the engine however, be sure to check your manifold and riser as a possible cause of the water in the oil.
clintbeastwood
Yes my exhaust manifold was cracked i drilled each end heated and welded. Its not leaking now that i can see. It still would not let the water mix with the oil would it? Unless the block is cracked inside? whats a riser?
clintbeastwood
I guess i need to change my oil n filter and flush it with something.Its just cold and raining. Its been sitting for 3yrs so im hoping its condensation. yeah i know fat chance!It runs great i ran it about 20 mins on muffs last week oil looked the same on stick just a lil milky it never climbed up the stick like a car will do as oil level rises? O well time will tell or an oil change.
Ayuh,... Cracked manifolds don't put water in the oil,...
The riser is the thingy bolted on the aft end, that redirects the water downward...
If the oil level ain't rising,...
Ya might be Lucky,...
