12v AGM Battery questions...
v1_0
I'm working on a project that will need some battery power. Looking at the choices of batteries, an AGM type best fits what I need - can be set on their side, won't leak, etc.
I'm needing 24volts, but the only batteries that I seem to find of that sort are aircraft starter batteries. I'm sure those would do the job, but they are rather expensive.
I've also read that you can take two 12v batteries and hook them up in series to get to 24 volts.
I'm looking at a drain on the battery(ies) of about 20amps or so for about an hour. So the batteries don't need to be particularly beefy - except that most batteries are rated for 20 hours of drain, and shorter drain times will shorten the life of the battery.
Based on all that, looks like I have a couple of options:
1. Go with 2 12v ~80AH Deep Cycle AGM batteries and hook them in series.
2. Go with 4 12v ~40AH Deep Cycle AGM batteries and hook them 2x2 (2 in parallel, then those 2 sets in series).
Here are my questions:
A. From what I understand, the second option is actually the better option from the point of view of "strain on each battery". The current drain is divided by 2 (parallel) and that's what is the main factor in battery strain/life. There is the possibility that I could go to a smaller size (30AH) - but from what I've seen there isn't much a difference in price between a 30 and 40AH battery. This leads into the next question:
B. Which brands of batteries are "better" in terms of reliability + price. I'm guessing that some of y'all use batteries a bit for your trolling motors, and may have some insight here... :)
-V
bream master
Re: 12v AGM Battery questions...
Hi mate,try DELKOR calcium deep cycle batteries,i hve one for my 55lb transom mount,and trust me they r a great battery and not overly priced mind you.:)
You are way better not having any batteries in parallel if you can help it.
You have looked at Optima batteries right? They have a 75Ah if that is big enough.
Ayuh,.... 4x 6volts.... Do they make 6V AGMs,..??
v1_0
You are way better not having any batteries in parallel if you can help it..
Please elaborate on why... I've read some (internet) articals that basically said that this actually extends your life beyond doubling the run time (more like 3x) because it spreads the current drain between the two batteries... BUT you have to have two identical batteries (type and condition, etc) - or you end up drawing heavier on one. I have no experience with this, so I can't judge on the 'reality' of what I read. (ie: some things seem to work well in theory, but due to real world conditions don't turn out as they would seem).
You have looked at Optima batteries right? They have a 75Ah if that is big enough .
Yes, I have - you are talking about the D31M.
Exactly for the reason you just gave. Also, if you have one low cell, it will prevent the good battery from getting fully charged.
j_martin
2 12 V batteries in series. When you parallel batteries, you will lose capacity at the rate of the worst battery.
That's why the trolling batteries in a bass bote can be put in parallel for charging during a main engine burn, (get what you can) but always have seperate independant circuits for finish charging in the garage. At that time they are always either isolated or wired in series (the isloation occurs in the chargers)
In Uninteruptable power supplies, battery banks are always in series. If there's more than one bank, each feeds a separate inverter and the outputs are synchronized (AC) and combined.
hope it helps
John
