1970LasVegas
- Joined
- May 1, 2012
- Messages
- 8
Hello all. I have an old trihull with a 140 mercruiser in it. I have water in oil. The compression test with wide open throttle is #1-140 #2-145 #3-150 #4-130. It idles pretty good but under load I can only get about 3000 rpm out of it. My manifold does have a crack on the side. Would the manifold cause water to get in oil or am I looking at a head gasket problem. Also getting blow by thru the pic valve. Thanks for any help.
