140 or 165
twincam1971
Hi, I just bought my first boat. Its a 1987 Sea Ray 18.5ft. It has the 3.7l mercruiser. I,ve found online that if it has the 2 barrel its 140 horse. And if it has the 4 barrel its 165. I only have the 2 on it yet my registration says 165. So is it safe to assume my Reg. is wrong?
Oh and new to the site also. Hi everyone. :D
cannonford57
Re: 140 or 165
welcome,you have a 165...with the 4barrel it is considered a 175...hope it helps
Re: 140 or 165
Ayuh,.... The 140hp is a Totally different motor....
twincam1971
Re: 140 or 165
Thanks for the replies. Guess I was looking in the wrong places for info. Glad its the 165. Just fired it up today. Sounds like it runs pretty good. Taking it out for the first time in the morning.
Bt Doctur
Re: 140 or 165
Before for take it out for the first time:
Download the manual and read it first
Test it in your driveway
Check the outdrive oil level
Check all battery connections
Replace fuel sep, if equipped
Drain plug in place.
Fill with fresh fuel
Re: 140 or 165
Glad its the 165.
Ayuh,... When the realty of owning a 470 sinks in,...
You'll be Wishing it was a 140hp...
The 3.0ls will run Forever,.... 470s rarely do...
