15 hp. short shaft Motor #OA757313 need lower unit
flyingscott
It was thrown out for a reason. Unless you get lucky they are hard to find used they are the weak spot on that motor. But the 6/8/9.9 and 15 hp all used the same lower unit from the late 80s on . There is a design 1 and design 2 but they interchange
trying to find a used one, good to know that 15 and under will fit. Any year from 80's to now.Thanks Ken
thanks, on the serial # only site I found was in Swedish, was trying to find out date made, Is there one in English.
Just because my handle is Finish Genius don't believe the last part of it.
