150HP and greater O/B GPH ?
K-2
Do you have an outboard 150 horse or bigger?
Tell me about the boat you have it on and how many GPH you burn @ cruise and what speed.
All brands, 2 or 4 stroke.
Thank You!
Boat: 22' Grady White Walkaround
Power: 200 HP, Evinrude Ocean Pro - 2 stroke
Full load of fuel: ~ #5,000
Cruise: 4200 RPM @ 27 kts.
Burn varies with sea conditions:
As measured with Garmin GFS-10 fuel management system
Glass: ~2.2 mpg
Normal: ~1.8 mpg
Rough: as low as 0.7 mpg
Fed
The old rule of thumb for 2 strokes used to be "1 Gallon per Hour per 10HP" cruising.
That would be 15 Gallons per Hour for a 150HP 2 stroke.
From what I've read you could safely work on 2/3 of that for a 4 stroke.
That would be 10 Gallons per Hour for a 150HP 4 stroke.
Frank Acampora
While my Force 150 is a thirsty engine I have never measured at full throttle. However I did have a Force 125 on a 14 foot go-fast. At 5900-6000 RPM and 55 MPH it burned through 16 to 18 gallons per hour.
Silvertip
Some misinformation here as usual. Yamaha probably has the most comprehensive Performance Bulletins for their engines. Pick a technology (2 or 4 stroke, pick your boat, pick your manufacturer and if they tested the exact boat you are interested in there will be test data for it. Fuel economy numbers at cruise is are valid ONLY for your boat, your water conditions, and what you consider cruise. The only number that is relatively firm in all of this is wide open throttle and as the performance bulletins point out, it doesn't matter what technology you pick, WOT fuel consumption is going to be the same or very nearly the same. Again, look at the data -- in most cases a boat is not even on plane with 4-stroke power until something close to 3000 RPM. Two strokes will usually better that. Therefore, when comparing 2-stroke & 4-stroke fuel consumption, use speed as the measure, not RPM and you will find the numbers come much closer than you've been told or thought. Why? Because a 2-stroke is generally pushing a boat faster at any given rpm than the 4-stroke. Those numbers are much closer with the very high HP engines but fuel economy at WOT is still 10% of rated HP across the board assuming all else is equal (that being engine HP, boat type size and rigging, and test conditions.
