150hp
procraftmark
I was looking at a 1990 150hp force and was wondering how well these motors held upand if parts would be available for the extended future?<br /><br /><br />thnx<br />mark
WillyBWright
Re: 150hp
They don't hold up well at all. Be religious about annual de-carboning and make sure that water pump is good and healthy. Most parts won't be a big problem since it uses all the same internals as the 3 and 4 cylinder models, but crankshafts and blocks are going to be in very short supply. The Prestolite ignition system is also a weak point and those parts are rather expensive if you can find them (medium blue components). Hopefully you have the newer Mercury ignition system . More of those parts are still available.
Re: 150hp
The 5 cylinder 150 didn't have the best track record.<br />94 and 95 models were a little better, but not much.<br /><br />The ignition system, with its blue coils and cd powerpacks, was a bad setup. Stator failure was common. And the old tilt and trim unit was troublesome. Parts are expensive, and some are no longer available.
Re: 150hp
Wow, looks like you posted while I was typing.<br />Geat minds think alike. :)
Deerdog
Re: 150hp
I had one on an 89 Arriva. I did have to rebuild it in 94. I maintained it pretty well and it gave me few problems but what what was said above it accurate. The ignition system isnt the best and the carb setup requires constant attention. They also like starters. I put three on mine over a 10 year span. I got rid of my old 150 b/c it was going south gradually and I didnt want to put any more into it. I now have a 150 Optimax and man what a motor. I do have a friend who still has one on his boat and it appears to still run fine. He swears he does only minimal maint on it.<br />IM not going to badmouth it b/c it did give us alot of good times - it just required lots of TLC.
Downrigger
Re: 150hp
Originally posted by WillyBWright:<br /> They don't hold up well at all. Be religious about annual de-carboning and make sure that water pump is good and healthy. Most parts won't be a big problem since it uses all the same internals as the 3 and 4 cylinder models, but crankshafts and blocks are going to be in very short supply. The Prestolite ignition system is also a weak point and those parts are rather expensive if you can find them (medium blue components). Hopefully you have the newer Mercury ignition system . More of those parts are still available.
How do you go about the de-carboning? Just got mine last year and I have no idea if it's ever been done. She ran good all last year without a glitch (besides an impellar replacement).<br /><br />Thanks,<br /><br />Larry
