18' 1981 starcraft SS
Watermann
You've done some fine work, she looks super nice! :thumb:
Motor work on older 2 strokes can be a real pain and expensive but essential. Are just the float bowls plastic? On my old motors and even my newer 1995 115 Merc, I replaced every fuel line, fuel pump kit, filters and carb cleaning with new gaskets finishing with a link and sync which includes checking the timing.
AceDuece
Hey Rikkie,
Boat looks great man! How did you mount up and brace your downriggers? The 16' SS I have appears to have had downriggers on it on a board across the connecting piece of the splashwell. I added cannon track to my port side gunnel and have a traxtech mount to put a rigger on it. But even with a piece of 1" wood backer inside the gunnel I really really don't like the way the way it looks.
Same thing with the board the PO has installed. Just doesn't seem stiff enough to me.
Rikkie
Thank you both for your comment
as far as the downriggers just backed them with 3/16 alum plates
as for the carbs there all plastic I'll give rebuild them a try but I'll have someone time and sink motor
Rikkie
I order carb kits
and order 4 replacement used carbs
I hope it's ok to talk about engines?
I am watering on parts so I started look at merc 850 I took off AS dissent want to start found some witeing problems....
Rikkie
I look at post before posting and my auot.correting changed a lot of words
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
I order carb kits
I will admit, I had to look at the picture with the Dewalt impact drill twice. At first I thought you had hot wired it to the wiring harness for some reason.
lol
I am getting old....
SHSU
Rikkie
Watermann/SHSU i tryed to send you guys amessage but it said nothing sent? I wanted to talk about mercury motors... but in the right place
SHSU
Don't know much about a Merc, other then a my 2 stroke kicker haven't worked on them per say. Now a 70's 70HP Evinrude, I can talk your ear off.
SHSU
