18 pitch to a 21 pitch prop
celtic gelf
well after some awesome help and info I finally got the boat cruising.....I did change props to a 18 when I was running a 21 before that.....I was told a 18 would give me better hole shot in pulling people outta the water....but I noticed the top end was 28 to 30.....with the 21 I was getting 42 at wot does this seem right??? I have a f5 150.... 1989 dash 1992... model frankenstein
Re: 18 pitch to a 21 pitch prop
Seems like a lot of difference in speed.
Only real way to know what is going on is to know your wide open throttle rpm with each prop.
Also need to know the wot recommended range for your motor.
This would best be discussed in the "PROPELLER " forum.
http://forums.iboats.com/forumdisplay.php?f=35
celtic gelf
kk thanks i'll repost it....I thought maybe my engine wasn't performing right tis why I asked here
pnwboat
If you have a tach, need to know the engine RPM's with the different props.
