18hp Johnson wont shift into gear after impeller change
tondss
ok guys I did an impeller change on my motor and I went to zip it all back up to find it wouldnt shift into gear. everything is in the right place as far as i know. The impeller hose is hooked up the rod linkage was hooked up good. I noticed if a loosed up the lower unit to were there was a half inch gap it would shift fine but as soon as i tighten it up it will only go in forward and neutral. it wont shift all the way down now. It was fine before. what is going on?
Did you line up the notch on the shift rod before you put the bolt into the the connecter ?
tondss
when you say notch do you mean the grove on both end of the rods? If so i tried to line them up best as possible. if its not perfect would it make that much of a difference?
The notch on both the upper and the lower shift rods MUST be lined up before you put the screw in.----And yes it does matter.---What other work was done on this lower unit ??
tondss
Ok thank you. It just needed some wd40. I works perfect now thank you. Nothing i just changed the empeller. And I have the exhaust gaskets now. i plan to zip it all back up today and see how she runs. i will give you an update as soon as im done!
hondarider188
could you post a picture of how the shift rods need to be aligned,because i am having a similar issue
