191 Islander wont plane off
191 wont come up on plane. no interior water problem. trim seems fine. 120hp 4 banger runs good. hung 10hp Yammy 4 stroke off back weighs about 150 lbs only 1/4 tank fuel when tested. any ideas? I'm stumpped!
jbcurt00
This 191 Islander?
Already gutted and rebuilt?
no. not gutted but have half the deck up on portside foam exposed, took out a couple of foam samples checking for water logged foam. was dry in good shape. was some h2o in bilge but not excessive.
Watermann
If everything was fine and now it's not then most likely a loss of power due to weak spark or fuel system restriction. Changing fuel filter and tune up should help.
