1953 evinrude big twin compression # # # ?
scot
Is there a know number for the compression on a 25hp evinrude big twin 1953 model 25012? is it in print or a guesstimate. both of my cylinders check the same. with in 4%
F_R
OMC never did publish compression numbers. Anything you see will be from experience, guess, rumor, witchcraft, etc. Hope for experience.
Those engines had about a 5:1 compression ratio, so 90 is good.
