1955 elgin 7.5?
82rude
i have nice elgin 7.5.its a 1955.i did not buy any parts for this motor but upon pulling flywheel every part under there is brand spanking new!! it has champion j 11,s are they correct?what are the starting carb settings?finally what is the purpose of the knob on the lower right face?
82rude
thanks good info.still cant find what that knob on the lower right face does.beside the low speed adj
Post some pics if you can, my dad had one of those when I was a kid..( now 72), would bring back some fond memories for me, thanks. On ours there was a green flip lever for the choke, a small knob for low speed adj to carb, and I remember Dad often dropping the glass bowl under the carb to clean the crud...and yes breaking a few of those glass bowls as they are slippery with the gas/ oil mix on them, even learned a few curse words from watching !!!
82rude
I believe the knob is fuel shutoff.looks like it needs a carb rebuild.Amazingly the md series carbs still have kits out there.
82rude
As long as compression is good ive no doubt this will be a strong running motor next year.Theres a vid on the bing and he says it a strong motor and his starts and runs like new.Ah thats youtube.1954 elgin 7.5hp short vid, impressive runner.Next up is my 1939 evinrude 22.5 opposed twin for redo.
82rude
Any suggestions for a gas cap.Currenty using a tap off of a 5 gallon water jug,lol.
brim_buster
You might find one on ebay. When I restored my Firestone I found some parts on there for it. Check the inside of the gas tank make sure no rust. I had to coat the inside of mine. Great little motors.
