1956 Mark 25 Point setting.
I B Dead Eye
What is the point setting on a 1956 Mark 25? I believe I remember 20 thousand but that's 50 years ago.
merc850
Here's a page from the owner's manual, set Nr.1 first then Nr. 2 at as close to 180* as you can get. mark25points.jpg
Section 1-4 says---" four equally spaced power pulses for each revolurion of the crankshaft "-----Now that would make for a smooth running 2 cylinder 2 stroke engine.
