1957 Johnson Javelin 35HP fuel issue
Alex Novo
Greetings from Florida: Fuel system was changed from pressurized fuel tank to vac fuel pump. Fuel return port its dripping. Reroute where or plug it?. Thanks in advance.
Actually the fuel pump is run by a PRESSURE pulse and not vacuum.------------And how was this conversion done ?---Pictures of your pump.-----Not sure what you mean by ---" fuel return port " ----but that air pressure supply fitting was used to pressurize the tank.-----It should have been plugged.
Alex Novo
Loud and clear. Thanks for clarification. Air pressure supply fitting will be plugged. Previous test where performed with fuel leak and a fire extinguisher near by jejeje. Conversion was done by replacing old system for a conventional 3 port fuel pump.
Joe Reeves
Small Error, A1 advice, Zero cost...... Sometimes'ya jest git lucky! :)
