1958 Johnson 5.5 Mikuni fuel pump problems
dockrat100
I have a 1958 Johnson 5.5 that I put a Mikuni pump #808492 on, and I am leaking fuel from the little copper colored disc on the top of the pump.
1. Is there particular orientation that the pump is made to work in? Flat, sideways, etc...
2. What is the little copper disc for?
The pump can be seen here:
808492 | eBay
nwcove
Re: 1958 Johnson 5.5 Mikuni fuel pump problems
Is this a new conversion? Or have you used the motor with the pump?
that disc is likely a smalll mesh to balance air pressure.... likely culprilt if leaking is a bad diaphram inside the pump
nwcove
heres a pic of a b&s pump mounted on a 7.5 johnson, the pulse line is obviously coming from a different location than it does on your 5.5, but for this pump, the top connector in the pic goes to the fuel in line, the bottom connector goes to the carb. if you are sure your lines are on right ( suck blow test), your problem could be as mentioned, a ruptured diaphragm.
edit: the part # for the pump shown in the pic is 808656, so your lines may attach differently, but the suck blow test still applies.
dockrat100
The motor will run with this pump, but it is dripping gas through the copper colored disc. Stinks, because the pump should be brand new, off fleabay, so not worth returning.
HighTrim
If it runs it has a bad diaphragm.
dockrat100
I will swap out to another pump. Thanks.
