1958 Mercury Mark 28
Hutiebar
Hi I have a 1958 Mark 28 and just got it started and within a couple minutes the motor is so hot you can't even touch it. Is this normal. Any help would be appreciated
You have to replace the impeller as step 1 of resurrection of any outboard.
So service the raw water pump
Not easy to replace the impeller on those.----Grey haired mechanic might be needed.-----Yes it needs a new impeller !
Oldmercs also has parts, tools, etc
