1960 Johnson 75 ho
61mysteryboat
I was just wondering what normal compression is for this motor. I just overhauled the engine and ran a compression check. It's only about 75 lb on all cylinders. I don't know if it makes a difference but it's below freezing up here today and the engine didn't turn over real fast.
That is probably OK. They were not high compression engines, just bulletproof. Are all the cylinders about equal?
