1961 johnson fd-15 18hp
Riverrat47274
Hello all!I just recently bought a 1961 Johnson 18hp motor and it is lacking power.runs about like a 9.9 or so.its on a 15' bass catcher.motor starts right up,idles good but top speed is just not there.i dont notice and bogging down or anything like that.just put new plugs in it today.if anybody
Can give me some things to check out what might be causeing this i would appretiate it.thanks!
Re: 1961 johnson fd-15 18hp
likely it is running on one cylinder.----It has a dual ignition system and one of the 2 may not be working properly.-----The only acceptable test here is as follows.----Make the ignition system jump a gap of 1/4" or more.---That is the proper test.---Laying the plugs on the block and seeing spark is " fools gold " and useless information.
boobie
Check the compression on it.
kfa4303
Banned
Hi rat. I have a '66 20hp, which is virtually identical to your motor and it pushes my 14' Tinny along nicely at around 20mph. I suspect you may only be running on one cylinder too. Thankfully, the compression looks good, so I would confirm that you are getting a nice strong spark capable of jumping a 1/4" gap. You want to use Champion J4C or J6C plugs. Here are some handy links.
3 HP Evinrude Lightwin Ignition System Tune-Up 1952-1967
Maintaining Johnson E & FD Serie
