1963 Evinrude lacks power at WOT
Rubixone
So here's the situation, I did points, coils and condensers and week or two ago, and then took it out for a spin and she was real slow, so I brought it back to the garage and decided to do a compression check and came up with 95 psi on both cylinders, according to the specs it should be 100 psi or better, so today I grabbed a carb kit and rebuilt the carb. And right now I am running the Yamaha ring free with a tank of gas, i would think it would have a little more guts than it does at 95psi, but at this point I am lost. its a quarter of the way through the tank of gas and still not any improvement... ho and yes it is running on both cylinders, as in I can start it on either one of the cylinders and it will run on one, but I am running on both.... Any ideas would be great!!!:confused:
thanks everyone in advance......
Joe Reeves
Re: 1963 Evinrude lacks power at WOT
Did you manually clean the brass high speed jet that is located in a horizontal position in the center bottom portion of the carburetor float chamber with a piece of single strand steel wire? If not, do so as cleaning solvent just doesn't do a proper job of cleaning that jet.
When in gear at full throttle, is the armature plate under the flywheel all the way up against the stop on the block?
Thing to check/double check.....................
(Synchronization Of Older 2 Cyl Engines)
(Such As The 28, 33, 40hp Etc models )
On the linkage that runs from the armature plate (the plate the coils & points set on) to the carburetor throttle roller, loosen the set screw on the brass collar that you see there and temporarily move it away from the armature plate/vertical throttle arm clevis (clevis is that thing the linkage rod slides through). We'll refer to that vertical throttle arm/armature plate clevis simply as the "clevis" from this point on.
Look at the cam that's attached to the front of the armature plate.... the cam that slides up against the carburetor throttle roller. You'll notice that there's a scribe mark on it. Also notice that at the top portion of the intake manifold there is a raised portion, that top portion forming a point. The carburetor roller should contact the cam and just start to open the throttle butterfly when the scribe mark is dead center with that point.
With the engine in gear (not running of course) have the armature plate advanced all the way (by hand) so that it is up against its stop. Now adjust the brass collar (set screw) on that associated linkage rod so that it is up against the clevis. It should be adjusted so that there is either no play, or just a hairs play between the collar and the clevis.
At this point, the armature plate movement is not advancing the throttle butterfly via the rod movement, but further movement of the throttle control, although the armature plate cannot move any farther, causes the tension spring at the armature plate to allow the vertical throttle arm to move farther which now advances the carburetor throttle butterfly via the rod. When fully advanced (full throttle), the carburetor throttle butterfly should be fully opened (horizontal).
If all else with your engine is as it should be, that should do it.
(Magneto & Driver Coil Alignment)
(J. Reeves)
To align the coils properly, have the metal vertical portion of the coil yokes aligned with the inside edge of the bevel that exists on the top portion of the aluminum seat upon which the coils sit. This creates the proper distance between the coils and the flywheel magnets. Faulty alignment creats friction and the yokes of the coils heat up, turn blue and expand.
(Point Setting Of Magneto Models)
(J. Reeves)
Set the points as follows. Have the flywheel key aligned with the fiber rubbing portion of the ignition points. Adjust the gap so that a .020 gauge will pass thru but a .022 will not. Should there be any question of the points being dirty (touching the contact with your finger would cause them to be dirty), clean them with a small brush and acetone or lacquer thinner.
NOTE 1: Should the operating cam have a small portion on it with the word "SET" imprinted, align this portion with the fiber rubbing portion instead of the flywheel key.
NOTE 2: Should the cam have the word TOP imbossed on the top of it, that is a cam that could be installed upside down and this is simply telling you which side is up. It is not a position where one would set the points.
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note 1: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
Note 2: If the engine should be a three (3) cylinder engine with three (3) carburetors, start the adjustment sequence with the center carburetor.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Have you tried doing a de-carb using seafoam or similar product?
lindy46
That compression is pretty low for a 40hp motor. Should be more like 120+psi
