1963 Starcraft 18' Holiday replacement windshield
mbanbury
I have a 1963 18' Starcraft Holiday. Looking for a replacement windshield that been shattered. Thanks
jbcurt00
Just remember iboats doesn't have a sales, giveaway or swap section, solicitation is prohibited.
May have to buy a derelict boat w a windshield that fits or can be made to fit your holiday.
Frame & windshield or just glass?
If you only need to replace the glass, and it's flat panels, local glass place should be able to order replacements. Or fab plexiglass, polycarbonate or lexan DIY.
Curved glass DIY:
http://forums.iboats.com/forum/boat...7423-bending-plexiglass-for-curved-windshield
Sorry some pix were lost during photobucket debacle...
mbanbury
Curved glass DIY:
My windshield is not glass, assume plexiglass. How ever. Would later walk thru windshields for a 18' Holiday work on the earlier Holidays?
jbcurt00
Look thru holiday resto topics, if it fits the width of your holiday, can likely be made to fit yours.
Problem is that later holidays tended to have a flatter front deck, your 63 probably has some crown to it. Hence Made to Fit. Not a plug and play swap.
Never use plexiglass, it scratches very easy ! Use polycarbonate ( lexan) far more resistant to scratches. You can even purchase " hardened" polycarbonate that makes it more scratch resistant. If you choose to use any type if plastic over glass, be sure you follow instructions on cleaning it!
matt167
With as popular as StarCraft is, you can probably get one from UDP plastics. They make them custom and then keep the pattern on file after that. Expensive though. Some glass shops can do them as well if they work with plastic
