1966 starcraft nassau restoration
bigmcgiv
well im new to boats, my name is matt. i just moved to south carolina. i figue i would get a small runabout to go on lakes around here. so all i know is its a 66 starcraft and a johnson 50 i belive 70s. anyi info would be a help. thanks
bigmcgiv
Re: newbie intro, starcraft id and johnson 50 id
Flickr: bigmcgiv's Photostream
bigmcgiv
didnt use spell check sry.
bigmcgiv
Please view my photos. Let know what you think it is. Thanks
In the Non Technical Section http://forums.iboats.com/non-boating...os-533219.html
Now in this section In the "sticky post" http://forums.iboats.com/boat-restor...on-288451.html there are links and one to the Starcraft index of restorations. ;) Tons's of info.
Nice boat......let's see...
Get the motor running and put it away.
Gluvit
I see a new rotary steering system needed.....
Seats, decking, transom, paint, plastic polish to clean the windshield, bilge pump, electrical switches,and the trailer....wheel bearings, tires lights.
Oh yeah Paint and more.
RULES: NO pressure treated wood...... Have FUN!
yooperangler
I would guess the motor is around a 72 looks like the electric shift controls so pre 73 i think you can find out by the serial number on the motor the guys on the johnson forum have lots of info. Looking at the windshield and layout in the boat Im guessing jupiter but thats just a guess . I think if the motor is a 72 hood would say 50 th anniversary on it ? Anyway cool boat and have fun fixing her up
bigmcgiv
ok my hull is fine not torn or damaged, im on a very tight budget so that being said what will last but wont break the bank on materials. no boat stores or marina near me need to be ready to find materials, thanks for the help in advance. here are pics of the boat.
pckeen
Hi Matt,
Can't help you on the motor or controls, but here's my 2cents on the interior restoration.
First - open a photobucket account - so you can post the pics directly into your thread - you'll get better responses that way. Simply upload your photos, click on the IMG link, then paste into the text here. Much easier for readers.
I see you have already started the teardown - looks good inside.
Before you begin rebuilding, read through some of the starcraft restoration threads, so you can get an idea about what you are getting yourself into. Once you've read two or three, you'll get the general idea of what you are looking at having to do.
If you are simply looking at replacing the floor and transom (given the condition of the floor, the transom is almost certainly shot):
If budget is an issue, use exterior grade plywood - NOT pressure treated, as that will corrode aluminum. It's cheap, and glued together with waterproof glue. Save the boards you have taken out so you can use them as a template for the new. Seal the exterior grade plywood with spar varnish (epoxy is better, but spar varnish should stand up well, and it is also UV resistant, so you won't need to coat it with anything to get some use out of it). Then put them back in with rivets or stainless steel screws.
In terms of getting seats and stuff - you could always build something out of exterior ply - but you may be better off checking out the seats available here on iboats (they are reasonably priced), or alternatively going to ebay to try and find something.
Good luck!
bigmcgiv
bigmcgiv
bigmcgiv
bigmcgiv
ok well i cleaned the boat out and removed it from the trailer, to redo it well the trailer needs alot of work. i completly removed everything and wire brushed it and now painting it doing alot of work on it.
bigmcgiv
comment, ideas , suggestions,
jbcurt00
And so it begins. Nice work on the demo!
Ever find the serial # on the Johnson?
bigmcgiv
i found the plate on the side
bigmcgiv
ok so if i go with exterior ply for the floor what thickness? is 3/4 too thick
bigmcgiv
did some work on the trailer i finished painting the frame, next is to clean and paint the axle, spring packs,and fenders.
bigmcgiv
taking a break today
Yeonik
Hey bud, good lookin lil boat ya got there. 3/4 is too thick on the floor, most of the tinnie guys are running 5/8 ply.
There's a ton more information in the starcraft forum as well.
bigmcgiv
well im trying to get my ducks in a row. should i remove the transom and replace it first before the deck or after the deck
