1967 Johnson 6hp prop
hockeynut19
I own a 6 hp Johnson. my prop bushing is spun, is there anywhere I can buy just the bushing? I can buy a new prop at $200 which is super pricey. thanks
Not sure where you are shopping but for that price, you should be able to buy a number props...do more shopping someplace else.....
If in Canada---------evinrudeparts.ca-----Might possibly help finding a used one.
Companies in the US ship to Canada all the time, unless your 6 hp is a rare bird, there should be a number of props laying around most prop shops, Ebay, or other marine shops. Small engine props are not normally in much demand.
QBhoy
Just get an aftermarket one. Can get thrown for less than a quarter that price. Not worth the OEM on an engine that size really.
QBhoy
i found a used one on ebay for $39, the aftermarket i found was $189 michigan wheel
Good deal. Nice one. Most will know by now…I’m a propeller nut! All for fancy expensive props on larger engines and performance boats. Spent small fortunes on propellers and more. But I’ll also come clean and tell you that I recently bought a cheap Chinese made prop for my 8hp and 3hp old Yamaha 2 strokes. Surely can’t be too bad for that use ?
hockeynut19
i can still use my old one.... i put 2 screws into the rubber bushing.....
