1967 johnson vxl13a 60 horse
Status
Not open for further replies.
VADER8674
hey trying to locate parts for this carb kit plug wire build kit and coil brp only goes back to 68 the carb for the 65 horse looks the same<br />any ideas also i understand it has a 6 amp alternator stator kind of thing does it feed this 6 amps back through the battery cables to the battery or does it have its own feedback wire
VADER8674
Re: 1967 johnson vxl13a 60 horse
does any one know anything about this engine
druskowsky
you can use an auto motive coil for a ford. part #26321 from carquest make sure it says on it "without external resistor" though. also it feeds charge amps through main starting wire that connects to battery. there is not much to the carbs a good cleaning without changing gaskets usually does it.
Daviet
You realise that this thread is over 5 years old!
Daviet
The mods don't like it when you open old posts.
randyinwa
thanks to the old reply dru....
good info on the carb.. and
I didn't know the other info about the charging... after mkt mans so suk..
Closed too old
Status
