1968 johnson 55hp Steering conversion
atengnr
Hello, I have the above, and in need of advice for using a rotary steering with this motor. I have a engine mount-bolt mounted steering arm tube for some time now, but it prevents tilting the motor up as the link contacts the steering arm tube. Could someone suggest a setup that works well?
Thanks alot!
I have welded some angle material to a tilt tube.----Mounted in such a way that it does not interfere.-----Or visit your friendly boat shop for a kit.-----Or research replacing your entire mid section with tilt tube and power / trim tilt to fit your lower unit and powerhead.
atengnr
Thanks. Is this doable on the 55hp, with hydraulic shift gearcase? Id like to have power trim, so this is great!
