1969 Cheiftan I/O trim hose help
Catfishcabin
So I picked up a 1969 Starcraft Chieftain about a week ago and I really need to get the trim lines replaced but I can't seem to figure out how to get them off. Please see attached picture and if you have any help and advice I would appreciate it thank you. This is my first post by the way glad to be here with my first boat
Bt Doctur
Well before you start spending money check the transom for and rot or soft spots, consider a donor boat for a transom replacement with a much newer type.
Catfishcabin
Transom looks pretty good it has a little bow to it. This coming winter I plan on replacing it. My buddy is getting a jig setup to build a rock crawler so hopefully I will be able to build a new transom. I may wait to do the trim then but the boat won't really plane with the broken trim and it's hard on reverse because the motor jumps up
Catfishcabin
What model gimbal assembly am I looking at? I'm trying to find more information.
Ayuh,.... Welcome Aboard,... Hard to tell with 1 picture,..... a really ole early MC-1, I guess,....
What motor is mounted to it,..??
For a replacement, generally speakin' newer is Better,.... late-70s or later,.....
Catfishcabin
No Title
120hp 4cyl. So I believe this is a Mercruiser 3.0? I've looked up Mercruiser Alpha ones and Bravo ones and neither seemed to have the same trim line layout. They all have a manifold under the gimbal housing where is mine is inside of the gimbal housing
Ayuh,.... The 120 hp is a 2.5l, but the exact same outside as the 3.0l,.....
Did you click the link to the manuals BD posted,..??
Follow the path to Mercruiser Manual #1,....
It's in there,....
Catfishcabin
I was having issues viewing it on my phone I will check it out on my computer tonight I appreciate all the help
