1970 Johnson 9.5
jsparks747
I picked up a 1970 Johnson 9.5 Sea-Horse at a neighbor's for $80 and am hoping to replace the rather beat up and dented prop. The problem is that it doesn't use the grooves like more modern engines and propellers, but uses a simple rod that goes through the shaft and locked into the back of the prop. I have been looking for a while anh have found plenty of props that are meant for the same make and model but they don't have the slot for the rod. Any suggestions?
Roberthill
Part #0763588 should work , slot in back that slides over shear pin . Lots of different models ,can you list model number?
You need to look for a 9.5 hp prop and not a 9.9 hp.-----The 9.5 hp props are all the same.
jsparks747
Thanks! I don't remember the exact model number but I do know the prop that was on there before was a Michigan propeller model #383315 8 1/2 x 8.
