1970 Mercruiser 165 Trim Down Problem
LDO6490
Just finished a complete bellows replacement and water pump replacement of my 1970 Mercruiser 165 outdrive. No problems with any of that. Hooked up my trim cylinders. Up is no problem and they push up with good force. Down is the issue. The drive trims down, but stops and inch short of full down (pump is running, but makes sound similar to when trimming up and it hits its limit) If you go up all the way up again and come back down, it stops about 2+ inches shorts of full down. This keeps on this way until it only goes down a little before it stops. I can get the drive to trim all the way down when I open the down port hydraulic line fitting on a cylinder and to let fluid drain and relieve the pressure.
1. Kept pump resevoir with enough fluid. Never let it run dry.
2. Bled pump up and down side in accordance with service manual #1 pages 7A-16 and 17 for Large Resevoir Black Pump.
3. Nothing is binding in drive. Cylinders do the same "not all the way in" as described above, even when not connected to the rear mounting pin.
4. No leaks in the hydraulic system noted anywhere.
5. System worked before with no problems until after I completed the bellows job. Trim cycliders were extended and tied pointing up while I worked on the other parts, about a week.
Frustrated and running out of troubleshooting ideas...
LDO6490
Re: 1970 Mercruiser 165 Trim Down Problem
Ooops. Messed up the title. Should be "1970 Mercruiser 165 Trim Down Problem"
LDO6490
Finally fixed the problem! Removed all fluid lines from the cylinders and worked the rams back and forth by hand until all of the fluid was purged. Noticed that they both did not move smoothly, especially the starboard cylinders. Service manual states that the cylinders should move smooth, especially when retracting. Opposite was true. DIsassembled the cylinders and examined. O-rings were ok, but there was sludge inside (especially starboard) and the end with the springs/ball check valves/ferrules was distorted, ball check valve springs could not move in and out freely because the aluminum around them had worn/deformed to the point where they were pinned against the side. I guess this kept the fluid from moving through the ball check valves properly which caused binding and fail of the cylinders. The aluminum ends were trashed, so I didn't bother with an o-ring kit and attempt at rebuild. Rebuild kit
Bottom line: Replaced cylinders with new Sierra 18-2142. Works like a charm. DIY victory!
Ayuh,.... Welcome Aboard, 'n Congrats on the repair,....
Sorry I didn't find yer thread sooner....
