1971 225 getting hot! At the end of my rope!!
I've got an old head question for anyone on a 71 225 OMC electric shift stern drive I have been working on forever. It gets hot is the basics of it. Runs 3/4 on guage at idle. Will slowly climb on a load and drop back to 3/4 when you reduce rpms. I have quite a list of what I have done to it so here it goes....
ck oil, has no water in it
Changed the impeller
set timing
replaced thermostat and housing
replaced temp sensor
Replaced water pump on engine
swapped temp indicating system from other engine (still runs hot on other indicating system)
put radiator cleaner in block on warm engine to flush
removed/reinstalled intake and heads....had heads magnafluxed and valves ck by machine shop
performed flow tests on each portion of cooling system. (found values in old omc book, so much per 20 sec ect...) Passed....small bubbles at first then clear flow on clear tubing
replaced 1 exhaust manifold that was cracked, inspected other and found nothing but cleaned it out anyway.
I'm at a loss and fairly frustrated any help would be greatly appreciated. I did ck engine with dig temp gun and it is running hotter than the other side but other is a newer engine
Thanks in advance...Skippy!!!
Re: 1971 225 getting hot! At the end of my rope!!
I would double check what you think your temp is by checking with an handheld IR gun.
Howard Sterndrive
despite the lack of bubbles, grease the swivel bearing at the lower unit- didn't see it on your list
was the clear hose test done in the lake? on plane?
I did ck with the heat gun but did not write down the temp, will do this weekend
Howard Sterndrive
the clear hose test was done only at idle, not under way.
it needs to be done on plane to be valid. Under load, on plane, you would most likely discover more exhaust gases than water being drawn in due to a lack of grease in the swivel bearing - service manual calls for grease twice per season ot keep exhaust out of the water pump intake path.
