1971 Trim Pump Replacement Question (135hp)
gidds
A couple of people have mentioned that I can replace my old (4) hose trim pump with the T1088MSK. It appears that this has (2) hose ports. Is there an adapter that would split the low and high ports? or is there another way to do it?
Thanks
Re: 1971 Trim Pump Replacement Question (135hp)
Gidds, I do not know about the validity of the pump replacement you mention, however, I would think that any hydraulic splitter would work. Since these are used routinely for brake systems on autos, I would try an auto parts store.
