1972 12.9 crysler outboard fuel pump assembly im lost
licketdsplit756
i took the old fuel pump assembly out not reliezing it had 3 gaskets. and the diaphram. i now have a new fuel pump assembly but dont know where the gaskets go or where the diaphram fits in btween with 2 gaskets a diagram would reall y help here thank you if you got any info. please help
Nordin
Re: 1972 12.9 crysler outboard fuel pump assembly im lost
Two gaskets are equal, they have one big hole. The third one has two smal hole and one lager like a half circle.
From powerhead and out they should be. 1. Gasket with big hole 2. diaphragm 3. gasket with big hole 4. fuelpumpbody 5. gasket with two smal holes and half circle 5. fuelpumpcover.
licketdsplit756
thank you wasent sure id ever find the answer. I came to the right place as always.i don't think ive ever not got a answer for difficult questions any where but in I boats. thanks again
