1972 Mercruiser 3.0L Choke Heat Riser Tube
reavesga
The choke heat riser tube is broken. Does that part just press into the exhaust manifold is the repair to just bend up a new tube, drill out the one in the manifold, and push the new tube into the hole? If so does anyone know the right size drill bit? Should I braze the new tube into the hole when done?
Just pressed in. Usually there is a hot air tube coiled inside the exhaust manifold that this connects to these can get corroded.
