1972 reinell rv1810
75boater
i just bought a 1972 reinell 18' 165 merc cruiser stern drive... looking for a place to find little stuff like manual trim plates interior things like that... any ideas? also looking to go to an electric fuel pump... any thought on this? good idea? bad idea? i will plan to have a reserve battery on board. today was the first day out on the lake with it... overall im pretty happy. i bought the boat for 700$ it didnt run or anything. put a 60$ batt in it. and tuned it up a bit, fired right up... now i just have a few things to do to it before our next trip out on the lake... heres a few things i need. Bilge pump, fuel pump, fuel pump blank for chevy straight 6, whale tail, ladder, and a new switch for the motor in ,out... any ideas as to where i could get these things for a decent price would be great. new to boating so any help would be sweet! thanks
tashasdaddy
Re: 1972 reinell rv1810
fuel pump engine, outdrive questions should be adderessed in the i/o forum. ebay is a place to look for old parts. i boats store carries many accessories. what make you think you need one of those horrible whale tails. put smart tabs on it. don't put the stress of lifting the boat on the old outdrive, put it where it belongs. on the boat. if you really want a whale tail, i have 2 sets in the shed, for postage. that i have removed from motors.
Bilge Pump,.... Right here at iboats,.....
Fuel Pump,..... Your local NAPA, Part # 18-7278,..... Forget about going Electric,... It's Not worth the Effort,+ Rewireing....
Fuel Pump Blank for chevy straight 6,.... see above....
Whale Tail,.... Ayuh, I'm with TD,....... Forget it,+ buy Smart Tabs........Much Better Idea.....
Ladder,.... Probably available Right here at iboats.....
New Switch for the motor in ,out,..... For the Trim,..??..??.... I Doubt it's the Switch,.... But it Might be...... Any momentary Switch will Work.....
But I'd do some Diagnosistic Work 1st......
75boater
alrighty thanks for the help guys... i spent about 2 hours searching the web last night and found just about everything i needed. ganna cost me about 1400 not too bad i must say...so the whale tail, no bueno? i friend had mentioned it saying it would get the nose down. like i say dont know a whole lot abut boating yet. but i could understand not putting an more pressure on the outdrive than needed. gatta tell ya guys you have been a great deal of help already! i thank you alot!!! sorry about not knowing where to post certain things i will get it figured out , thanks again
75boater
where can i buy these smart tabs? the ones that go on the boat are the fixed plates that you adjust by hand... where could i get those? all ive been able to find are power trim plates
