1972 Starcraft Islander 21 project.
Getoffmybass
y4mWBxqQ0fSE1Z7bHEdo5VvNcTAnrxQzmP0h5RW_iBwI6HTbdbtsFNdyfr2JL9CWDjc_EJ2Zrv8DCr6F-GfIIWgf4aKThqIqkgJ2X_PmbV2noNnnlSN8D29NBdgdpcaz7HLxW9csAymjWtMMECcXjV_2PSsIWRM7T6G2bcXI-FsJJ7eKQjZw333C-jPhZQLcQJlboSeSFqfEiJfqqUf-nAZ_Q
Getoffmybass
Really need to thank Watermann for the One drive tutorial ! Nice to see the pics embedded and no need to follow a link...
Getoffmybass
Put together a pressure washer sandblasting rig, ideas off youtube.. got a pot blaster from harbor freight,,, set to 40 psi,, used some screened playsand, used respirator while sifting. 3.5 0 degree nozzle 2.7 gal min 2800 psi,, did well, no clogging, and it stripped the small 12 footer inside and out with 4 bags of sand..
Getoffmybass
looking at the spring, Single axle should be enough to carry the Islander.. upgaded to 15in tires 1700lb capacity each..
Getoffmybass
Finishing up the new trailer for the Islander,, now that Ive got the hang of pressure blasting and painting,, i can get to work! Thinking of ditching the inboard,, needs the head milled a shop in Raymond can do it with the head still assembled..get that running and then sell it to finance more of the boat materials...
Watermann
Now you're cooking with the pics, :thumb: Awesome to have that unsavory pile of work behind you on the trailer. Looks to me like a 3500 Lb axle, should do just fine.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Looking really good. I was debating doing the same thing with a pot when I redid my trailer but didn't have the space to setup and do the blasting. If i am ever able to get some land to work on, will defiantly get my own pot.
italianstal27
I picked up a 3.0L merc 140 for $100 on craigslist last year. We're planning on taking it in to get decked and honed for a complete rebuild.
There really are a decent number of cheap engines out there that people would almost be willing to pay you to take if you have an engine hoist to get it out!
It seems a little daunting at first, but there is a tremendous amount of information on the site related to rebuilding a merc 120/140. Once completely rebuilt, you'll have the peace of mind knowing it should last you many many years with proper maintenance! :)
Just an option! but we really like the i/o
-John
