1973 Starcraft SuperSport 16ft. restoration questions
Well, the universe gave me something else to consider today. Fired up my Ariens snowblower, that has worked great for 9 years (first one lasted 16 years) this afternoon, to clear the 2 feet deep snow from the driveway. Ran about ten feet, blowing the snow about 30 feet, and suddenly no snow coming out the chute. Thought I broke a shear pin but it wasn’t that. The impeller engagement rod was loose and extended further out of the machine than normal. “Oh darn”, says I. “I can fix this in a jiffy”, says I. It was 4:30 pm and 18 degrees with the garage door up for light and using metal wrenches was not fun. The impeller rod end wasn’t connected to anything, a brass sleeve had fallen to the bottom of the housing unit, idler pulleys had become separated from the belts, and a large spring looks to be broken. I stopped looking at that point because the ten digits at the end of my ungloved hands were getting numb. I am unable to get a vehicle from my garage to the street. Did you ever call a snowblower repair shop for assistance after a blizzard? I swear I could hear hands rubbing together and a bit of laughter when discussing repair and pricing. One shop offered to come pick the machine up, make the repair, and bring the snowblower back….for $124 trip fee. $95 hour labor plus parts, tax, and whatever on top of the trip fee. I have a truck and a trailer here at home and can’t use either at present. Talk about frustrating. So, after some thought I am considering getting a new snowblower, repairing this one myself later when the weather is warmer, and donating the repaired snowblower to the county folks who help out the senior citizens (which is what I did with my last Ariens snowblower). So, saved new boat motor funds will most likely go towards a new snowblower. At least some of the money.
Or, I could just gas up the snow shovel and do the driveway the old fashioned way for old times sake, or talk a neighbor into using his snowblower to clear my driveway, or get someone to plow the snow out of the driveway. Lots of fun here in Up North Michigan when it snows! Looking forward to Spring. 🙂
Safe boating,
Joe
One reason to always help out the neighbors when ever I can, some day it will get related ! We live out in the country and everyone sort of relies on other neighbors when things go haywire. We don't often get a lot of snow, but on occasion we get clobbered. For that reason I have two blowers ( yep one is an Ariens) as well as a plow blade on my side x side. Also a neighbor down the road with a pickup and blade. We all pitch in when we get dumped on. I tend to have more toys than I really need because I try to be self sufficient. At age 75 that is becoming more difficult...but I have great neighbors.....that alone is worth its weight in gold !
piperjoe
Got to thinking about the boat this afternoon and stepped outside to check on the ‘ole gal. After more than 144 inches of snowfall this Winter the boat isn’t going anywhere soon. There’s a 4 foot high snow bank currently at the edge of the driveway that has to melt away so I can back the truck down to the boat hitch, too. However, it’s forecast to warm up and I’m maintaining a positive attitude; I can sure use the boat restoration as a diversion from some of the sadness around this place. Have pretty much decided to get a 40 hp, 4-stroke, short shaft engine for the boat as I only want to take the Admiral out for cruising around the lakes and do some fishing. Whoever gets the boat after I’m done with it can put something larger on it if that becomes necessary.
Safe boating,
Joe
piperjoe
Once the boat gets to the driveway I’ll finish sanding the marine plywood to remove the remaining raised 3M putty welts over the decking rivets. After a couple of paint coats brushed onto the reachable inside aluminum hull I can glue the deck carpet to the marine plywood as a one piece unit. That’ll keep me busy for a few hours or so!
Safe boating,
Joe
piperjoe
The original decking was all removed earlier and I replaced it with new marine grade plywood during the restoration work. Have not pulled the tarp yet this year though no decking problems are anticipated.
Safe boating,
Joe
piperjoe
It’s 38 degrees right now and the snow is about 80% gone. Forecast is saying it will be in the 50’s - 60’s starting tomorrow and throughout the upcoming week. This should allow me to hitch onto the boat trailer and get the boat to the driveway. Got my fingers crossed 🤞! Had my toes crossed too but it’s hard to walk that way…
Safe boating,
Joe
piperjoe
Beautiful and sunny afternoon today and the snow is disappearing quickly. Lots of rain yesterday and last night with more on the way over the next few days. So I took a chance on the yard being solid enough to drive my Ranger pickup on it and pulled the boat/trailer onto the driveway. Lifted the tarp up from the transom area and there was a very small amount of water in the bilge area, not even enough to run out the drain opening. I was extremely pleased to note the inside of the boat was dry. Now I can begin the restoration process again as time and caring for the Admiral permits. More later. 🙂
Safe boating,
Joe
piperjoe
Lots of rain around here since bringing the boat to the driveway. Extreme flooding, road washouts, potential dam failures and evacuation plans enacted. More rain inbound within the hour so there won’t be any boat restoration work for awhile.
Once the marine plywood top decking surface is cleared of the 3M putty, sanded and vacuumed, I plan on applying two coats of West Systems epoxy in similar fashion to the epoxy applied onto the plywood bottom surface and edges. After allowing sufficient time for each epoxy coat to chemically cure I can then lightly sand the top epoxy surface in preparation for the carpet glue. This should help to keep the decking intact and feeling solid for some time to come. That’s the plan…
Safe boating,
Joe
Well I assume your evacuation plan includes having a boat in the driveway....
I did the old timers formula as well as a marine epoxy paint, three coats both sides. My kids should inherit a solid boat.
piperjoe
What brand of marine epoxy paint did you use, and, would the paint be a good choice for the inside aluminum hull from the decking upwards to the gunwale? Would this paint be a stand alone application of two brushed coats, or would I want to brush it on over aluminum protection paint (don’t recall what it is called)?
Safe boating,
Joe
I used rustoleum Topside marine paint for the floors. Im sure it would be ok on the aluminum with the proper primer but not qualified to say definitively. I will let other chime in.
piperjoe
After doing some research on the Rustoleum Marine Epoxy paint I realized I had checked this product out earlier and had pretty much decided to use it on my boat. There is also a Zinc-Cromate primer or Rustoleum marine primer for etching the aluminum surfaces prior to using the actual Rustoleum Marine Epoxy paint. Also, there’s a good color selection to choose from and the paint is available at Lowe’s. I will most likely be going this route for my paint work.
Safe boating,
Joe
piperjoe
Man, I’m not believing this weather in Up North Michigan. Ever since I hauled the boat to the driveway we have had massive amounts of rain. Last night the destructive storm system that was in Wisconsin crossed Lake Michigan and dropped much rain in our area along with some of the loudest and long lasting thunder I have ever witnessed. Frequent lightning got my attention, too. And now it’s 38 degrees outside with 2 - 3 inches of snow forecast for this evening and tomorrow. The crazy thing is that it was 78 degrees yesterday but I spent the day doing appointments and errands. Oh well, we are supposed to have 4 or 5 days next week with forecast temperatures in the 60’s and 70’s. Hopefully I’ll be able to accomplish some restoration work on the boat. That should make me feel better! 🤞🙏🙂
Safe boating,
Joe
piperjoe
62 degrees and rising along with a beautiful blue sky and sunny day! I’ll be climbing into the boat today if all goes well. Sure looking forward to that!
Safe boating,
Joe
piperjoe
Life can be a terrible thing at times. Have the boat ready so I can get back at the restoration work but have not been able to because of devoting my time to taking care of the Admiral. Joyce has been having more difficulties due to her Dementia, namely her ability to remember things, such as names, places, recent events or who I am and where she lives. Sometimes it’s very hard for me to keep a smile on for my bride of 57 years (Anniversary this coming Sunday) though I give it my best try.
I designed and put in a nice curve style paver patio with a fire pit for her in celebration of our 40th wedding anniversary and she spends a lot of time there enjoying the woods, flowers, bushes and the birds. However, on sunny days it can be a bit too warm for her. So, knowing the route her dementia is taking, I purchased a Cedar gazebo kit and and new patio furniture to place within the gazebo as my 57th anniversary present for her. Brought it all home yesterday and unloaded everything on the patio with help from a neighbor. Those boxes were heavy!! It took us a good hour of steady work to get everything off my trailer while Joyce stood by and watched. After Joyce helped me throw a large tarp over everything and tie it down we went into the house ‘cause I was needing a couple of pain pills for my back. A few minutes later when I was taking the medication Joyce came into the kitchen rather quickly and asked me what was the big thing on the patio that was covered with a tarp, who put it there and where did it come from. Joyce was with me the entire time we hooked up the trailer (she helped me get the truck and trailer hitches aligned vertically) and during the entire loading process at the store as well as the time spent unloading everything onto the patio. She had forgotten everything within a matter of a few minutes (and I had a few more tears to wipe out of my eyes).
This morning when looking out the bedroom windows she asked about those tarped boxes again.
Long winded I’m sure, though intended to show why there’s been no further progress reports from me regarding the boat restoration. There are additional reasons as to why I need to stay close to my precious bride to keep her safe though the above will suffice to illustrate the situation at our home.
I will post when I have some restoration progress to report though I will ask for your prayers and understanding through these difficult times. My first and only consideration of real importance is to take care of my best friend and sweetheart of my life.
Safe boating,
Joe
