1974 850 mix ratio
craigman
Fellas, i have a 1974 Merc 85hp. What gas/oil mix ratio should i be using?
thanks!
Craig
chum1
Re: 1974 850 mix ratio
50/1 about 1 qt per 10 gallons of gas is what i use
Chum, You gave the wrong ratio. It is 1 pint/6 gal of gasoline or 1 quart/12 gal of gasoline.
craigman
Thats ok, i have a mix cup! As long as i know it's 50:1 i'm good to go!
Thanks fellas!
chum1
If you fill 3 bud light with lime bottles with 2 cycle oil that = 's about 1 quart good for about 10- 12 gal's of gas as the day progresses the bud light calibration math gets a little fuzzy and as long as you are close and put oil in all will be fine.
I don't like limey beer. How many Corona Extra bottles worth? Dos Equis? Molson Ice?
chum1
alright corona calibration for you and an extra shot of 2 cycle J?germeister for me
Gomer50
AHH, 750ml Jack Daniel's + 12 pack of Coke = Ohh hell ran out of gas long time ago (where am I ?? ).. @ 50:1 mix
Jager does sorta look like 2 cycle oil. I hope I do not mix them up sometime. That would be hard on the motor.
