- Joined
- Oct 25, 2011
- Messages
- 25,274
Re: 1974 Ebbtide Restoration
The transom lip you trim 1/2 off is usually under a metal trim strip
Cuts 1 & 4 are only to loosen the cap from the transom, you aren't cutting the exterior surface of the finished gelcoat, or at least as little as possible.
Cuts 2 & 3 are thru the tabbing on the underside of the splashwell, in the seam between the splashwell & the transom. And you try to NOT cut thru the exterior side of the stern transom fiberglass skin.
Running cut #3 diagonally up thru the transom wood. You may or may not be able to connect cuts #3 & 4. That's what the vertical sawzall cut between the inner & outer fiberglass skins is for, joining cuts 3 & 4
