1974 Galaxy Restoration
ampedzach
So, I'm working on prepping for some gel coat for my restoration, but I'm worried that my boats hull is paint. I know that gel coat doesn't stick to paint very good. Is there a way that I can decipher if my hull is paint or gel coat?
Re: Gel Coat, or Paint?
Ayuh,.... Is it original,..?? What makes ya think it's paint,..??
Post a picture...
jbcurt00
Set an acetone rag on the suspected paint. Leave it for a bit, if the surface starts to wrinkle & lift = PAINT. If it doesn't it's likely gelcoat......
ampedzach
Would a laquer thinner work?
ampedzach
Post a picture...
It's original, but I've only had it for about 6 months. I think it might be paint, cuz I'm taking some pin-striping off and the supposed paint is just chipping really easy.
jbcurt00
How are you removing the pinstripe?
If you're not using a pinstripping removal wheel:
You can find it w/ a google search
perhaps it's the removal method that's causing chipping. Because the method could chip either gelcoat or paint, easily........
Intriguing... 6mo you've owned it 'new' to you or it was factory/showroom new when you bought it?
As often is the case, pix would certainly help
ampedzach
This is the pin-striping I'm trying to get off. It's just tape so I was using a razor blade.
ampedzach
You can see the spot above the pin-striping that definitely needs work. It's like that in a few spots on the boat.
ampedzach
I bought this boat back in August with a non-working engine. It has a 5.0 Ford with a Merc out drive. I got it home and got it running with a few things. I let it sit through the winter (way too cold to work on any of it in Utah!) I tore out the carpet and seats because I was planning on redoing the interior. When I pulled out the seats and carpet I found some soft spots. The strings feel solid (so far), but I think the whole deck is shot.
jbcurt00
Might be dock rash on either paint or gelcoat, the staining down the hull sides & onto the bottom is odd though....
Ayuh,... Under the tape seems to be a different color, what is it,..??
Start sandin' on the rash, it's All gotta be sanded anyways,...
If it's a Very thin color, 'n then another much thicker color, the thicker color is the gelcoat, 'n the thinner color is paint, probably from a PO...
ampedzach
The brown paint is really thing and all the white paint is thick. I'm thinking the brown is paint and the white is gel coat.
