1975 Clinton K500
ckswanecamp
SPECIFICATIONS
BORE AND STROKE---------------2 3/8 x 1 5/8
DISPLACEMENT (Cu. In.)---------7.2
IGNITION-----------------------------high tension magneto
MAGNETO POINT SETTING-----.020
SPARK PLUG------------------------Champion Type J13Y or equivalent.
SPARK PLUG SETTING-----------.025
CARBURETOR----------------------Float
CRANKSHAFT-----------------------Forged
BEARINGS (engine)----------------Neddle and Ball
BEARINGS (gear housing)--------Bronze
STARTER----------------------------Recoil
FUEL SYSTEM---------------------Fuel Pump
GEAR RATIO-----------------------13 - 22
PROPELLER TYPE---------------Shear pin - Semi Weedless
PROPELLER DIA. & PITCH-----7 - 4 1/2
STEERING--------------------------180' Pivot Reverse
LUBRICANT (Gear Housing)-----Part No. #951-247
FUEL MIXTURE--------------------3 ounces Motor Oil to One Gallon Regular Gasoline (24:1 of 2cycle Chainsaw Oil is User Recommended )
IDLE SPEED------------------------800 RPM
FULL OPERATING RANGE-----4500 RPM
PEAK HORSEPOWER-----------At 5600 RPM Sea Level Barometer at 60' F.
ckswanecamp
Re: 1975 Clinton K500
ckswanecamp
Here is a link to a shop that carries parts for antique outboards. I purchased a complete gasket kit and lower block seal for $25 delivered.
http://www.discount-marine-parts.com/ob_clinton_2.html
CLINTON ENGINE PRODUCTS CO.
605 E. MAPLE ST. PO BOX 860
MAQUOKETA, IOWA 52060-0860
(563) 652-2411
I really hope this thread is helpful to some. I have been wrenching on this outboard for a few months now. It took me plenty of research to learn about this motor and Clinton Motors Corp. I do own a owners manual (which i will post here in text format soon) and a compltet parts list. Please email me at ckswanecamp@yahoo.com if you have any questions regarding this motor. Its been a pain in my fn ***. And yet I still tinker wit this piece of junk. LOL
Gibbles
Thank you!
very helpful for me :D
pretty close to my K751
sutor623
Hey buddy, I have a big favor to ask. Can you tell me what spark plug is used with the k751 in that manual that you have? Thanks a ton!
