1975 OMC 120 tilt question
Fishingtime
I just purchaed a 1975 Fiberform 18.5Ft boat with a 120 OMC outdrive. I realize that the drive is designed to operate in the full down position. My question is can the drive be operated in a partial tilt position at low rpm when navigating shallow water or backing off a shore. I have not put the boat in the water yet and thought I should ask this question before doing any damage. My first outdrive.<br />Thank you, Dan
Re: 1975 OMC 120 tilt question
No........<br /><br />If you Do,<br />You'll be Replacing the Ball Gears in Very Short Order..........<br />Along with Parts of the Tilt System.........
Boomyal
The ball gears on my 20' 302 are now 29 years old. Other than a bit of rust you can't tell them from new. On very rare occasions I will tilt the outdrive to get out of a tight spot that I did not mean to get into. Other wise the drive stays down. Recommend you do the same.
