1976 Johnson 85 HP Bolt Size
oswana21
Is anyone aware of the shoulder bolt that holds the bellcrank and shoulder pin assembly. Also, I stripped out the female part of where it attaches to the motor head. I was planning on using heli-coil. Does anyone have any other recommendations?
Yes I have worked on those.----Not sure how you could strip that bolt and thread on the block.
