1976 Johson 15 HP spark test need help
Seahorse16
But my main question is the ignition coils. If I switch the coils and they work for the other cylinder, then doesn't that mean the coil is my issue and not wires, Condoser or points?
Up to you to investigate whether this ignition system fires when the points open .----Or whether this system directs a charge from the one driver coil to the proper cylinder coil through the points that are still closed.
AlTn
yes...if you have one good coil that works on either cylinder and one bad coil that works on neither, then that external coil is bad,..IF...the wire connections, grounding points for the coil ground wire, spark plug lead to the spark plug etc. are good...disclaimer, I have never personally fooled with this type ignition set up and what insight I have has been gleaned from other Forum members...my understanding is that each point set serves as the ground for the other point set so that is why cleanliness and grounding points for the components under the flywheel is critical ; clean grounds are essential for this system..before you condemn that coil I suggest you do the following..pull the boot off the spark plug lead < yes it will just pull off >..you'll find the wire coil that the spark plug end snaps into..pull that out of the plug wire < has a spike that pierces the wire > now cut 1/4" to 1/2" off the lead and reattach the wire coil, lube the boot with some rubbing alcohol and shove the plug coil back into the boot, check for spark..yes or no to spark now?...
Seahorse16
Thanks AITn. I will try this. Now I don't have spark in either cylinder. I must have fowled something up in there, huh? Now I need to figure out what I did before I can test your suggestion. Ugh
Seahorse16
Do you think it's most likely I fouled the points up or is this a grounding issue? I tried cleaning points and nothing. Hmmmm
