1977 85 horse Merc Tach install
achris
More fish than mountain goat
Re: 1977 85 horse Merc Tach install
In the front end of the control box is a 3 pin connector. That connector is for the tacho harness. It has +12 volts, ground and the tacho signal, which originates from one of the charging coil wires where it connects to the rectifier, it should be gray in the engine.
Chris.............
Actually Chris, on those old motors the tach wire is brown. The grey wire runs the choke.
