1978 115hp Johnson Telltale modification
Pat2009
A while back I remember reading about a mod to move the telltale hose up on the engine to prevent air getting trapped in the upper starboard side. Can someone point me to the SB; I cannot find it.
Thanks.
Re: 1978 115hp Johnson Telltale modification
The 1978 really does not require the modification but, you can run a longer hose looped over the top of the block.
