1978 20ft bayliner Liberty
Virago85
Ok heres the deal I have a 1978 20ft bayliner Liberty I had no motor are out drive when I got it I have recently bought a mercruiser 350 with mercruiser stern drive I just found out that the gut that had the boat before my cut a bigger hole in the Transom for a Volvo penta drive my ? is how would I go about fixing this so I mount the mercruiser stern drive.
Are is there an adapter I can buy for this
Thanks for your help
Robj
Re: 1978 20ft bayliner Liberty
Why would you want a Merc anyway?? Go buy a Volvo. Otherwise, I agree, replace transom. Maybe with some creative carpentry you can cut out the center part of the transom and then install new wood, glass it in and then cut out the smaller hole.
When I replaced my transom, I cut out all the rotten wood and then joined the new wood to the existing solid wood. Worked out great and it was not that difficult. Maybe post a few pix so others can comment.
Good luck
Rob.
Virago85
The reason for the Mer is I have 4 Kids and a wife and have to go with what I can afford LOL I got the hull and trailer for $200 no motor then I bought trashed hull a rebuilt 350 with only 8 hours on it and the out drive for $500 (good deal I thought but the block was cracked from not winterizing correctly) but still I fell the out drive was worth the 500 now for some pictures
http://www.shareaproject.com/imageUpload.php?i=3812
http://www.shareaproject.com/imageUpload.php?i=3813
http://www.shareaproject.com/imageUpload.php?i=3811
http://www.shareaproject.com/imageUpload.php?i=5484
http://www.shareaproject.com/imageUpload.php?i=5485
http://www.shareaproject.com/imageUpload.php?i=5486
http://www.shareaproject.com/imageUpload.php?i=5487
http://www.shareaproject.com/imageUpload.php?i=5489
http://www.shareaproject.com/imageUpload.php?i=5490
http://www.shareaproject.com/imageUpload.php?i=5491
http://www.shareaproject.com/imageUpload.php?i=5492
Virago85
Ok Got all the old Plywood out today Lots of chiseling and grinding lol I cut my stringers about a foot back and when I replace them I was going to replace with some Knee boards for extra support I'll probably cut it from a 1x12 are something of sort what type of plywood would you recommend for the transom will get some pictures as soon as the rain lets up
Also The transom will be built up I was planing on grinding the glass down from the inside about 6 inches around the hole then build it back up with matt and 6 inch reinforcement tape by going matt tape matt tape then once I have it built up I am going to beef the transom up with a couple of layers of matt and cloth
That sounds like Alot of Build-Up......
The Final Over all Thickness has to be 2" for the Mercruiser to Work......
Virago85
The glass is 1/4 inch thick now so if I use (2) 3/4 inch plywood and that gives me a thickness of 1 and 3/4's so I still have a 1/4 inch to go the hole will be built up to level with the transom then I will add two Layers of matt across the whole lenth of the transom
