switzer140
- Joined
- May 29, 2013
- Messages
- 35
Ok well everything was going good out on the lake today probably the hardest i have ran the boat this year. We were out for 5 hours or so tubing, skiing, and boating non stop. I dropped a few passengers off at the dock and my son and i were out cruising around the lake when the engine started sputtering like it was loosing power i put it in neutral and it died. Would not restart. We sat there adrift for quite a while till i could flag someone down to tow me back. Once we got back i checked everything over it seemed to be there was no spark. it was definitely getting fuel and the bulb was still firm but no fire. we tried to check to see if it was getting spark at the plug by 1. holding a screwdriver in the boot and holding near the block, nothing. pulled a plug grounded on the block and nothing. So we let it sit and grilled some food. came back about 1 1/2-2 hrs later and it fired right up let run for about 10 min and seemed to run fine once again. I didnt take it back out as it was starting to get late and almost everyone else was gone so if i got stranded i wouldn't have a way back. I was kind of disappointed that it restarted because i think it is going to be harder to tell what is wrong, and i don't want to be stuck in the middle of the lake again. Any ideas on what i can test or do to figure out what went wrong? It has 2 brand new cdi's and new plugs in it before i took it out today.
