1978 Johnson 140hp running rough. Need advice
Bman2895
They certainly not my Favorite Item either, but many times I have removed them on Carbs that the Owner insisted were spotless, and found a pile of Gum/Varnish/Dirt hiding behind them with no way to get out.
On the Carbs with fixed Idle Jets, Settings like the Float become Critical, as well as proper Gasket Fitment, as you mentioned above. Wear on the Throttle Shafts can become an issue over time, as that can allow excessive Air to enter, which is undesirable as the Throttle Plates are Fully Closed at Idle, actually quite higher than Idle Speed, and an Lean Condition can occur.
Well I have noticed there throttle shafts do have some play. I'm gonna source some good rebuild kits. Get it all back together and then I heard someone say to try some axle grease around the shafts to help determine if they are causing an issue.
Bman2895
On the topic of float height. I read the idea is just to get the end of the float opposite the needle just above level with the body of the carb correct?
And what was the sealer recommended for the welch plugs? Recall reading about it but can't seem to find that post again
I have always set floats level with no trouble but others may have better info.
Some people use nail polish on the plugs.
I have used form a gasket on a few that I was suspicious of and had no problems with it.
A good rebuild kit will give you specs for setting the float along with other adjustments. As far as sealing the plugs, if installed properly, no sealant is needed. With low compression, everything needs to be set just right to run correctly.
Bman2895
Well I've found some OEM kits local. And yeah I can tell it's picky. For a moment yesterday it was just about right. The off idle was decent and the idle was steady.
Maybe the plugs were crappy and undersized or maybe I'm just not knocking them in hard enough to expand them fully.
It’s doesn’t take much to tap them in and you can go to far and they will become lose again.
I have killed a few over the years by saying I’ll give it one more tap. 🤬
Open Water
Berryman carb cleaner. Gallon can, remove carb soak according to label. Replace/rebuild kit. Might just help you out.
Bman2895
Little update. Had time this week to get the carbs back on. Fired it up on water horns and its back to idling good on all 4 again. Will take it to the lake this weekend to test in the water as again.
I would be planning on a rebuild as Racer said... 100-110psi is too low. those 78' 140's had very tight heads unless someone replaced them for crappy fuel. im sure it will run for quite a while so if thats all your after no worries, but it would be a different motor once properly bored and finish honed to the next size. id be worried about carbon sticking the rings over all these years. after a rebuild i advise premium fuel and full synthetic oil (after walmart dino-juice break in oil) and an engine tuner decarb every season without fail.
I would never use premium fuel if the mfgr recommends regular grade. Doing so can make your engine less powerful as premium fuel burns slower. Numerous studies have shown this, if your engine actually runs better, then you have issues besides fuel.
for most engines thats very true, but not with these specific crossflow V motors! the heavy piston crowns soak up a lot of heat. add the other reasons I listed above and premium fuel is absolutely the logical/better choice. And no, it doesnt reduce power. if anything it increases it.
Unless the engine compression and timing is set up for premium fuel, the use of this fuel will actually produce less horse power ! Talk with any gasoline engineer, much has been written and tested on this subject.
Premium fuel does not produce more heat as far as I know.
Only if ignition timing has been altered.....higher octane fuel is for advanced timing and high compression engines. When high octane fuel is used in low compression engines or those with retarded timing, it can cause a extra heat buildup while it produces less power.
Why the synthetic oil after a dino brake in oil ?
Premium Gas has a lower BTU Value per Volume than Regular Gas, plus, it burns slower. Unless the Engine is requires Premium, you can end up less Power and poorer Gas Mileage, plus Higher Operating Costs
agreed. problem is these crossflows run hot/lean in the midrange. those thick piston crows soak up a LOT of heat!
Bman2895
You sir hit the nail on the heads. So after a couple trips it's done decent. Still has some issue just falling on its face when you punch it from idle. I decided to recheck compression with a new tester. Got right at 115 on each cylinder. Thought the slight increase was interesting but I chalked it up to the tester? I had been running better oil though it.
Decided to use my buddies bore scope to take a quick glance inside. Kinda expected scoring or something. Turns out its in awesome shape. Its got 4 newer 30 over weisco pistons. ( got the part numbers and the over bore off the top of the pistons) the cylinders even still faintly have some crosshatch. SO now I know this engine had a full rebuild and the lower numbers definitely dont add up. Decided to check the heads and wouldn't you know it. Both heads from a 1989 110hp. (Going off part numbers on the heads.)
The Heads for the 135 and 140 were certainly higher Compression than those lower HPs
