1979 9.8 Carb Bowl
keithb7
I have been struggling to get the carb bowl to seal. I also ordered a new OEM Quicksilver gasket kit. It won’t seal. I’ve tried adjusting the float level incase it was over fueling. No improvement. The old cork bowl gaskets seem long gong. The ethanol in todays fuel may be a contributing factor. The bowl seal swells, enlarging. It won’t go back in its groove. Left to dry for a week, the seal seems to shrink and then is too small. I tried some tricks that were mentioned on FB groups. Boil the seal. Freeze the seal. No improvement.
Seen in the photo is the extra seal material that will not fit into the seal’s groove, once it has become enlarged. Has anyone had any success with an RTV type gas-proof tube of goop to shape and my my own seal? Or perhaps cut the OEM seal, taking a section out to makke it fit. Then applying said gasket filler to the gap to get it to seal. Any tips appreciated as this is frustrating.
i am not aware of any ethanol free fuel here in Canada.
keithb7
Following up to share success in resealing the bowl.
I cut the seal. I fit it in place and cut off a piece as it was too long. I fit the seal tightly in its grove ensuring a good tight fit. Removed seal. Carefully applied a thin layer of Permatex Motorseal sealant which does not break down when in contact with gasoline. I put a little extra where the cut seal joins. I let it set up, carefully pushing the seal back in place where it tended to move a little. Sealant was given time to set up. All appeared good. Put a thin layer on the outer surface of the seal where the bowl contacts it. Used my finger to spread and smear a thin layer. Let it sit for 20 mins. Installed bowl and tightened it down. Re-installed carb and let it sit for a few hours to let the sealant to cure. Hooked up the fuel line. Primed bowl with the hose bulb. No leaks. Started engine ran for 20 mins at various RPM. No leaks.
How long will it last.? How long until sealant breaks down? Will it? Time will tell. Will test on my boat on the water later today. I will update this thread as time passes. So far this is the first time the bowl has sealed properly despite my efforts. Wish me luck.
I used something similar to seal the gaskets on my fuel tank sender. It seems to hold up. Hopefully you have the same luck.
I am concerned about you not being able to find a carb bowl seal that works. Is it possible that you got some old stock (pre-etoh) when you bought the new gaskets? The swelling of the seals should not happen.
That is an old school compression (seal) gasket. One time use only.
Had the same issue in my old 2 stroke golf cart where the orginal gasket is NLA.
It took some searching, but was able to find the proper “square” , nitrile seal for the groove. Had to buy a box of 100 (life time supply +) but $25 well spent given the alternative.
I would not use gasket maker on a carb unless deemed “disposable”. When the stuff breaks down you end up with a carb full $rap. Clog a jet, run lean and blow up the motor
keithb7
Agreed @dingbat if/when the silicone breaks down if will plug up carb orifices. I wanted to do something to prove where the leak was coming from. My mind was settled when this worked. I will consider finding a quad ring to seal it up long-term. Something ethanol-proof.
Nitrile or viton….watch the durometer.
90 durometer Viton is too hard for a carb gasket
keithb7
As of today, this 1979 9.8 is now my spare back-up outboard. After a few weeks of thinking it through, visiting each dealer, lifting each outboard to check weight etc, I made a decision. A new 2025 Merc 9.9 EFI is now mine. I purchased extended premium warranty too.
There has been set backs and reliability issues with my older Merc engines. I just want to get out on the water, relax and have fun sometimes. Not experiencing a 90% probability of an engine issue of some type or another. I’m hopeful reliability will now be 100% for quite some time. We shall see. l plan to continue to tinker and use my 2 stroke now and then. It should make a good back-up plan if ever needed.
I love to fix the old stuff but, reliability takes a much higher priority out on the ocean, or a river. Or a massive lake in a remote area of Canada. Getting home/rescued is something to seriously consider. It’s not like tinkering on old vintage cars, which I am used to.
